Hei
https://slantsix.org/forum/viewtopic.php?t=21193
Author:  ROADRUNNER7169 [ Fri Dec 22, 2006 11:35 am ]
Post subject:  Hei
Hi iv been searching the forum all morning and i cant seem to find exactly what i'm looking for, first i have a stock 74 dart 225 and i have the dual ballast what do i do with the 4 wires off the ballast. In the HEI mod post from Dan it states "take the two connectors that used to connect to the resistor, and connect them to each other instead" well i'm just asking to clarify (so i don't fri something in my car) do i connect the two wires in the same connector together or the two wires on the same side together? Also will this mod work on the 74 distributor. And again sorry if this is just another stupid question.
Author:  SlantSixDan [ Fri Dec 22, 2006 12:15 pm ]
The ballast resistor is totally eliminated when you do the HEI upgrade.
Your 4-prong ballast resistor has-
At one end
Dark blue wire connected to a terminal, AND that wire jumpered
over to the other terminal on that same end
At the other end
Two brown wires (We'll call "Brown A", "Brown B") coming off one terminal
One dark green with red tracer coming off the other terminal
What you want to do is connect the dark blue to the dual-brown. You can pull the jumper and the green/red off the ballast resistor and remove the resistor entirely, or you can just leave 'em in place, it doesn't matter; they won't be used in the new setup.
Yep, the HEI will work with a '74 distributor.
Author:  ROADRUNNER7169 [ Fri Dec 22, 2006 12:32 pm ]
COOL THANKS MAN (YOU PROLLY HEAR THIS ALL THE TIME BUT "YOU ARE THE MAN")
Author:  SlantSixDan [ Fri Dec 22, 2006 12:48 pm ]
Glad to help...I'd rather hang out on here answering questions than face customers at this time of year. Granted, they keep food in my fridge, but I can only take so many emergency phone calls from people who "forgot" that Christmas is 25/12 and they want parts not in stock shipped to arrive by, um, yesterday. :roll:
Author:  Ron Parker [ Fri Dec 22, 2006 4:07 pm ]
Here Comes Santa Dan Here Comes Santa Dan right down Santa Dan Headlight way. :D
It Aint Over Until I Win
