| Pinion question https://slantsix.org/forum/viewtopic.php?t=21195 |
| Author: | sixsignet [ Fri Dec 22, 2006 12:49 pm ] |
| Post subject: | Pinion question |
This is a 63 Valiant /6 auto trans car: My driveshaft angle is 1.5 - 1.75 degrees down My rearend is 0 (zero) degrees Will a 2.5 degree axle shim correct this pinion angle? |
| Author: | sixsignet [ Fri Dec 22, 2006 8:41 pm ] |
I installed the shims and now the nose of the rearend is tipped down at 3 degrees. |
| Author: | SlantSixDan [ Fri Dec 22, 2006 8:50 pm ] |
3° is on the "too much" side of things. These wedge-shims are best installed less-than-you-think-you-need at a time. Maybe back down to a 1° wedge? |
| Author: | sixsignet [ Fri Dec 22, 2006 9:08 pm ] |
What should the pinion angle (driveshaft+rearend) be for my car? I think I was reading the wrong article... |
