| Motor mounts https://slantsix.org/forum/viewtopic.php?t=21199 |
| Author: | GENT [ Fri Dec 22, 2006 9:30 pm ] |
| Post subject: | Motor mounts |
The rubber bushings inside my motor mounts look worn out,does anyone make replacements? ANyone make Poly replacements? THe car is a 76 Dart. Thanks |
| Author: | Bren67Cuda904 [ Fri Dec 22, 2006 9:48 pm ] |
I found inserts from Autozone. I bought the whole mount with the insert already in them from them. I converted from the flat type to the spool. I notice that stuff rattles inside the passenger door at idle now. Are the spool type mounts firmer or are the inserts likely in wrong? |
| Author: | slantzilla [ Sat Dec 23, 2006 7:22 am ] |
I am not 100% sure, but the poly spool trans mount bushing may work in the motor mounts too. |
| Author: | GENT [ Sat Dec 23, 2006 8:26 am ] |
Where would I find the poly trans bushing? Do they have one to replace the mount for my A-833? |
| Author: | slantzilla [ Sat Dec 23, 2006 8:57 am ] |
Quote: Where would I find the poly trans bushing? Do they have one to replace the mount for my A-833?
I got one from Summit. It is for the '73 and up crossmember/mount. Mine was just the insert. |
