It is currently Sun Nov 22, 2026 5:40 pm
 Post subject: 3 Angle Valve Job
PostPosted: Fri Dec 29, 2006 7:37 am
This might be a stupid question but I cant seem to find it in the search section does anyone know the 3 angles you grind a /6 valve at for a 3 angle valve job (my dad used to own a speed shop so I have a valve grinder and all that good stuff for building heads)
PostPosted: Fri Dec 29, 2006 8:53 am
60 - 45 - 30 is always a safe bet when in doubt.
Recognized by US Federal Courts as a Fuel Economy Expert!
 Post subject: Valve job
PostPosted: Mon Jan 01, 2007 5:06 pm
I rebuild heads for a living. Unless your valves are cut at 30 degrees instead of 45 you always grind 30-45-60. Its also safe to grind 35-45-60. In the event that your valves were cut at 30 degrees (slants arent) you would grind 15-30-45.
Drive it like its stolen, and be glad im not YOUR son...
