3 Angle Valve Job
https://slantsix.org/forum/viewtopic.php?t=21253
Author:  ROADRUNNER7169 [ Fri Dec 29, 2006 7:37 am ]
Post subject:  3 Angle Valve Job
This might be a stupid question but I cant seem to find it in the search section does anyone know the 3 angles you grind a /6 valve at for a 3 angle valve job (my dad used to own a speed shop so I have a valve grinder and all that good stuff for building heads)
Author:  mpgmike [ Fri Dec 29, 2006 8:53 am ]
60 - 45 - 30 is always a safe bet when in doubt.
Author:  74W100/6 [ Mon Jan 01, 2007 5:06 pm ]
Post subject:  Valve job
I rebuild heads for a living. Unless your valves are cut at 30 degrees instead of 45 you always grind 30-45-60. Its also safe to grind 35-45-60. In the event that your valves were cut at 30 degrees (slants arent) you would grind 15-30-45.
