It is currently Sun Nov 22, 2026 9:25 pm
PostPosted: Thu Dec 28, 2006 4:55 pm
Hi, I come here for your expertise on carbs, hopefully for webers.
This weber DFEV 32/36 23A was originally from VW 1.7L air cooled off the ebay and I'm putting this on caravan's 2.2L to replace ailing holley 5220 carb.
If someone have done one for 2.2L engine size for jetting and MPG on jetting set up. I'd love to have this info.
Thanks and Happy New Year, cheers, Wizard
PostPosted: Fri Dec 29, 2006 6:26 pm
i was a dealer and installer for Webers for a few years...just put it on GRT
PostPosted: Fri Dec 29, 2006 9:38 pm
I second that. Is going to work OK.
Juan Ignacio Caino
 Post subject: Really?
PostPosted: Sat Dec 30, 2006 12:37 pm
Seriously? What make you think this will work because this is unexpected response but this would be very nice to know that. What make the set up for 1.7L aircooled work fine on watercooled 2.2L? Do the aircooled needed to run slightly richer or what?
Reason I ask about jets setup rejig is this carb jets appears to be not stock config that I see on weber's data sheet for DFEV. The jets is at least 1 to 2 size larger than stock 170 and 140 I think for the air mains visible.
I have to get rebuild kit to replace old stuff that might have gone bad with storage.
Curious to know that. ;)
Oh, new thoughts popped up: The spark computer control rely on manifold vacuum so I have to re-reoute this from alterative source and
I thought of using the capped off ingition spark advance port as EGR port.
Also there is a manifold port but is plugged with a rod besides the idle mixture screw. Could use that instead if I swap this round rod for a nipple from my collection of junk holleys.
Cheers, Wizard
PostPosted: Sat Dec 30, 2006 2:37 pm
air cooled engines run hotter and needs more fuel, yes. They run way richer than most water cooled ones, that's why you'll be fine. Air main jetting doesn't show nthing besides that previoous owner might have been leaning out the carb by using larger air bleeds. This works better than stepping down in main jet sizes, mostly because adding emulsion air to the fuel makes it more stable for better air/fuel mixture atomization. This might have been used on a water cooled engine, and instead of rejetting it, they just used bigger air mains.
Juan Ignacio Caino
PostPosted: Sat Dec 30, 2006 9:22 pm
i sold them for years and installed most on a wide variety of cars from 1.4L to 3.0L. the factory jetting in a 32/36 A or E series always worked fine on all applications. (with the same jetting) only time i tinkered with jetting was to get the MOST out of it in a race application which gaineds where slight. :D
