| Throttlebody Question https://slantsix.org/forum/viewtopic.php?t=21290 |
| Author: | Greg Ondayko [ Mon Jan 01, 2007 10:50 am ] |
| Post subject: | Throttlebody Question |
If I were to put a throttlebody setup on say a clifford 4bbl intake manifold Would it require a heated manifold Like a carb? or is Throttlebody smart enough to compensate for that? Thanks, Greg |
| Author: | SlantSixDan [ Mon Jan 01, 2007 11:47 am ] |
You'd probably want to find a way to heat your intake, yes. A TBI system is still a "wet manifold" system, subject to the same issues as a carbureted wet manifold system. Fuel will still condense and puddle on the floor and walls of a cold intake. All factory TBI systems I'm aware of have heated intakes and thermostatic air cleaners. You could put a water-heated spacer under the throttle body, which wouldn't be as good as water-heating the floor of the intake below the throttle body, but combined with a thermostatic air cleaner setup would probably get you by OK. If I were putting TBI on a slant, I'd almost certainly use a thermostatic air cleaner up top, and one of Frank Raso's manifold heat kits on something other than a Clifford intake (Offenhauser, modified factory piece, etc.—something originally equipped to bolt onto the exhaust manifold. |
