It is currently Sun Nov 22, 2026 3:19 pm
PostPosted: Mon Jan 01, 2007 5:08 pm
Installing aftermarket oil pressure guage, Anyone have any suggestions were the easiest place to install it into the oiling system?
Thanks
5258
PostPosted: Mon Jan 01, 2007 7:07 pm
On the oil pump, where the pressure sender for the dash light goes. You will more than likly have to get a brass adapter to install the kit...just get one the same thread as the sending unit. If you like, you can also get an adapter so you can run both the pressure guage line and the sending unit so you keep the dash light. You'll notice the red light before you see pressure loss on the guage.
PostPosted: Mon Jan 01, 2007 8:27 pm
Just to make sure that's underneath the oil filter to the left, If your standing on passenger side.
Thanks
5258
PostPosted: Mon Jan 01, 2007 9:16 pm
Thanks
5258
Yep, that's it.
Used to own:
'82 Dodge D150
Erson 270 Cam, O/S valves, mild port work, ~9.5:1 compression
Currently fighting with an '85 VW Cabriolet
My other passion
PostPosted: Tue Jan 02, 2007 3:45 am
Many of the aftermarket kits will include a small assortment of common size brass adaptors- If not, as Eric W. stated, just bring the original sending unit and the aftermarket one to your favorite hardware store to match up the proper adaptor size...
PostPosted: Tue Jan 02, 2007 2:46 pm
Hooked it up today, works great, thanks to all for there advise.
Users browsing this forum: Amazon [Bot], Bing [Bot], Google [Bot] and 18 guests
