It is currently Sat Nov 21, 2026 12:26 am
 Post subject: Performance.
PostPosted: Fri Jan 12, 2007 7:22 pm
Any tricks to pick up a few extra horses from the 225 with out spending too much money?
1969 Dodge dart 225/6
PostPosted: Fri Jan 12, 2007 7:35 pm
SSRN National Champion
How much is to much money. Thanks Ron Parker
It Aint Over Until I Win
PostPosted: Sat Jan 13, 2007 2:50 am
Probably the best "bang for your buck on a budget" would be to swap the intake and carb for a "Super Six" setup (2-bbl). These are pretty inexpensive and easy to get from junkyards or eBay.
Next would be either to have the head shaved by .050 to .100 thus raising the compression ratio; or else change the rear axle ratio to a steeper set of gears (many slant six powered cars had a 2.76 or 2.94 gearset to help with fuel economy and highway cruising).
The 2 bbl and the compression ratio change may actually net you more MPG along with the horsepower increase. The gear change will give you a "seat of the pants" feel of power but probably lower your MPG.
-Mac
PostPosted: Mon Jan 15, 2007 11:48 am
How much does it cost to shave the head? I have never had any experience with that. As for the intake and carb what kinds of prices are we talking. I'm will to spend a couple hundred dollars 500-1000 at the most. :D
PostPosted: Mon Jan 15, 2007 12:53 pm
Shaving the head will first off require the purchase of a head gasket set. If you have the equipment to remove the valves yourself, the machine shop I deal with charges $35 for a shave involving a single cut. When I had 0.055" taken off my /6 head it required 2 cuts and they charged me $50. If the shop has to disassemble the head for you, it will cost more of course. If they do that work for you, have them freshen up the valves and add a 3-angle cut to the seats. Go for an improved cam. I used Comp Cams 252-M with satisfactory results.
This will keep you in your price range.
Mike
Recognized by US Federal Courts as a Fuel Economy Expert!
PostPosted: Mon Jan 15, 2007 1:11 pm
When I had my head done it was almost $500 for cleaning and magnifluxing, 0.100" shaved off, valve job, new valve guides, one new valve, reassembly, and the gasket set. I took it to them disassembled. You should easily get a super six and a cam for the rest of that $1000.
PostPosted: Mon Jan 15, 2007 7:05 pm
The shop I use gets $45 for a 6 cylinder head. And $45 to shave the block. I thought it was a deal.... Did my own valves....Tanked it....and knurled the guides. I know it's not the best, but it was free. :)
Bought a $60 spring compressor and assembled myself. It's not easy, but doing stuff like that yourself can save you a heap of money.
Hey.....Can't you get a great nitrous setup for $1000????
225 Cubic Inches of Iron-Head American Muscle
225 bored .040 /.100 off block, Schneider Cam 224@.050~ .480 lift - Stock valves, blended bowls, Offenhauser intake with 500 Edelbrock carb
PostPosted: Tue Jan 16, 2007 5:14 am
There are many nitrous systems available at swap meets in a wide range of sizes and prices. I purchased a complete 250 HP plate system for $100.
I would not reccommend using anything larger then a 125 HP system on a slant with stock pistons.
PostPosted: Wed Jan 17, 2007 5:02 pm
As a true tightwad, I would start with a tune-up first. I Like the Bosch Platinum plus two spark plugs. Get some performance wires. That is, if it is a daily driver. Then add a high flow air filter. These will help later as you do the milling, cam etc.
PostPosted: Thu Jan 18, 2007 6:52 pm
Sssshh They'll bite your head off. :twisted:
PostPosted: Thu Jan 18, 2007 7:54 pm
Come on Charlie, where's your sense of adventure? :lol:
PostPosted: Thu Jan 18, 2007 8:02 pm
In the scrap aluminum can with the pistons :cry:
Users browsing this forum: Amazon [Bot], DuckDuckGo [Bot] and 3 guests
