| Rods/Pistons/198vs225 https://slantsix.org/forum/viewtopic.php?t=21333 |
| Author: | Rug_Trucker [ Fri Jan 05, 2007 11:16 am ] |
| Post subject: | Rods/Pistons/198vs225 |
Can I do a direct 225 swap with my 198 rods and pistons? Or will the pistons be too high? |
| Author: | Rug_Trucker [ Fri Jan 05, 2007 11:20 am ] |
Oh yeah what is the rod lengths? |
| Author: | SlantSixDan [ Fri Jan 05, 2007 11:24 am ] |
198 rod is 7.006" 225 rod is 6.699" Piston is the same on all slant-6s. Use a stock piston with a 198 rod on a 225 crank and the piston will run into the cylinder head. You have to use a piston with a higher pin bore to run 198 rods on a 225 crank. |
| Author: | Rug_Trucker [ Fri Jan 05, 2007 11:35 am ] |
Thanks Dan! |
| Author: | slantzilla [ Fri Jan 05, 2007 11:50 am ] |
You can use the 225 crank and rods and make a 225. To use 198 rods you need 2.2, VW, or custom pistons. |
