What Gear Ratio?
https://slantsix.org/forum/viewtopic.php?t=21391
Author:  73NorthernDuster [ Tue Jan 09, 2007 8:15 pm ]
Post subject:  What Gear Ratio?
Ok
I bought a 8 1/4 out of a 74 duster it is all apart but was cheap enough. I got it home and it is an open rear with 3.55 ratio. A week later I found another one out of a 75 dart all together this time and an sure grip for the same price(':D'). I opened it up and it's a 3.21 (':cry:')
Now my Question. Should I keep the 3.21 or pull the good rear apart and throw the 3.55 in. Will I notice much of a difference on modified slant with stock converter? Input and experiences appreciated
Thanks
Brent
Author:  slantzilla [ Tue Jan 09, 2007 8:37 pm ]
Personally I'd leave the 3.21 together and run it. You won't see enough difference between the 21 and 55 to warrant the trouble of tearing it apart. :shock:
Author:  AnotherSix [ Fri Jan 12, 2007 9:34 am ]
If your engine works well with a stock converter the 3.21 should be just right all around. Even with with realistic street v-8s and tires around 25" - 26" diameter I have always liked ratios in the 3.20 to 3.40 range. When you get to 3.5 to 3.7 ratios it is just over the line for highway driving unless it is a high rpm engine or a truck with larger tires.
Author:  DusterIdiot [ Fri Jan 12, 2007 11:55 am ]
Post subject:  The other shoe...
Or you have one of the Overdrive transmissions then it is just fine.... (and actually makes the first 3 gears really "fun" in town).
Author:  73NorthernDuster [ Sat Jan 13, 2007 9:17 am ]
Post subject:  Thanks
Thanks for the input. I guess I'll keep the 3.21's and maybe use the other as a spare just in case or use it for some $$$ towards something else.
