| Schneider cam specs https://slantsix.org/forum/viewtopic.php?t=21392 |
| Author: | BigBlockBanjo [ Tue Jan 09, 2007 9:44 pm ] |
| Post subject: | Schneider cam specs |
Hey Jess, and others who were waiting The cams specs are: 264* dur. 224 dur @ .050 0.480 lift w/stock rockers Int. opens @22, closes @62 Ex. opens @62, closes @22 Overlap is 44*. 110 Lobe centerline, 108 intake centerline Still waiting on the springs. I called Schneider, and they were very quick and polite about it. He is sending me some more springs, shipped them the day I called. Jess, I think it was you that were researching cam profiles. I read somewhere that "major" brand cams are roughly designed around a program based on 4 in. bore/3 in. stroke motors. I can believe that... When you start working with longer strokes.....the valve "windows" need to be stretched to later after BDC, to make up for the extra stroke length, and increased pumping losses. I had to sit and think about it a while...but it makes sense. Just thought I'd throw it out there.... Take care.... BBBanjo |
| Author: | Matadem [ Wed Jan 10, 2007 3:43 pm ] |
I have that same cam, the springs they send you with that cam will be dual springs so don't forget the retainers for them... |
