i need help with a 2 barrel carb.
https://slantsix.org/forum/viewtopic.php?t=21410
Author:  MXN002 [ Thu Jan 11, 2007 4:05 pm ]
Post subject:  i need help with a 2 barrel carb.
ok, so i think i want to get rid of my single barrel carb and go for a double. so i got a different intake manifold of course. do i just need the 2 barrel carb? or is there anything else? i can't imagine it being that simple.. does the carb come with every else thing i need? and what carb do you guys recommend??
Author:  carrigan #3 [ Thu Jan 11, 2007 4:51 pm ]
i'm not the most experienced one to say...but i have heard many told these things before...
the carter bbd is an often used two barrel and you will most likely have to find/fabricate some goofy stuff for the throttle and kickdown linkage...i'm sure someone more knowledgeable will chime in with more details...good luck!
Author:  sandy in BC [ Thu Jan 11, 2007 6:08 pm ]
http://www.slantsix.org/articles/supersix/article.htm
