It is currently Sat Nov 21, 2026 12:00 pm
PostPosted: Thu Jan 11, 2007 4:05 pm
ok, so i think i want to get rid of my single barrel carb and go for a double. so i got a different intake manifold of course. do i just need the 2 barrel carb? or is there anything else? i can't imagine it being that simple.. does the carb come with every else thing i need? and what carb do you guys recommend??
PostPosted: Thu Jan 11, 2007 4:51 pm
i'm not the most experienced one to say...but i have heard many told these things before...
the carter bbd is an often used two barrel and you will most likely have to find/fabricate some goofy stuff for the throttle and kickdown linkage...i'm sure someone more knowledgeable will chime in with more details...good luck!
My Dart
GO VOLS!
It's not rocket science, we're just splitting atoms.
PostPosted: Thu Jan 11, 2007 6:08 pm
http://www.slantsix.org/articles/supersix/article.htm
