It is currently Sat Nov 21, 2026 10:19 am
 Post subject: Help with ´71 Duster
PostPosted: Mon Jan 15, 2007 7:17 pm
Since a week I got this problem with my good Duster, starts fine at first try (even with 2 celsius degrees), idles excellent, but when it comes to move the car, it moves rought, even tries to die, but everything goes smooth when reaching second gear. This does not happen often, but happens.
Also, this problem always happen when starting the car after some time it
ran.
I already expulsed a little garbage from the cab by accelerating it and choking the carb, my mechanic and said that the problem is not the carb (even try my carb in another car, and it ran very fine), but he was´t avaible to check the car, what can the problem be?
Mopar Muscle is well defend by Slant Six!
Valiant Duster 1971
PostPosted: Mon Jan 15, 2007 7:27 pm
If your Duster still has points, I'd check there first.
Mike
Recognized by US Federal Courts as a Fuel Economy Expert!
PostPosted: Mon Jan 15, 2007 7:31 pm
It gots electronic ignition, also the forum is awfully slow or is just me?
Valiant Duster 1971
PostPosted: Mon Jan 15, 2007 7:38 pm
If you're sure it isn't the carb, the next place to look is the ignition system. Do you have a carbon tracer running down the inside of the distributor cap? How bout a coil wire touching something and shorting out briefly? I'm afraid it's just time to do the horrid diagnostic routine! Just go over the individual components and verify that they work properly.
Mike
Users browsing this forum: Bing [Bot] and 8 guests
