It is currently Tue Nov 17, 2026 5:08 pm
PostPosted: Sat Jan 20, 2007 10:31 am
I have a '66 B 8 3/4" housing/brakes/axles. And open 3:91 chunk of unknown vintage. What to look for when assembling and problems. (whole axle needs disassembled cleaned)
What will it take to put under the Duster?
Can I use my present drive shaft and universal joint?
PostPosted: Mon Jan 22, 2007 4:55 pm
You might be able to use the U joint, it will depend whether or not the 8 3/4 is a 7260 or 7290 joint. The driveshaft will have to be shortened a bit. You will need to relocate the spring perches. This is what I did when I had an early B axle in my 70.
70 Dart, 360, 727
Users browsing this forum: Amazon [Bot], Bing [Bot] and 2 guests
