| '66 B Body 8 3/4 Into 72 Duster https://slantsix.org/forum/viewtopic.php?t=21530 |
| Author: | Rug_Trucker [ Sat Jan 20, 2007 10:31 am ] |
| Post subject: | '66 B Body 8 3/4 Into 72 Duster |
I have a '66 B 8 3/4" housing/brakes/axles. And open 3:91 chunk of unknown vintage. What to look for when assembling and problems. (whole axle needs disassembled cleaned) What will it take to put under the Duster? Can I use my present drive shaft and universal joint? |
| Author: | Lars [ Mon Jan 22, 2007 4:55 pm ] |
You might be able to use the U joint, it will depend whether or not the 8 3/4 is a 7260 or 7290 joint. The driveshaft will have to be shortened a bit. You will need to relocate the spring perches. This is what I did when I had an early B axle in my 70. |
