| MITSU 3.0 L Pistons in a SL6? https://slantsix.org/forum/viewtopic.php?t=21569 |
| Author: | Tjordan4 [ Tue Jan 23, 2007 7:07 am ] |
| Post subject: | MITSU 3.0 L Pistons in a SL6? |
Anyone know what kind of machine work would have to be done. I came across a set of pistions and they are a good bit larger then stock Sl6 pistons.Any ideas would be great. Thanks. TJ |
| Author: | Doc [ Tue Jan 23, 2007 8:19 am ] |
What is the piston diameter, pin size and compression heigth? DD |
| Author: | 440_Magnum [ Tue Jan 23, 2007 10:08 am ] |
Even if they could be made to work, I'd have reservations. The piston design on the 3.0 was a big part of its eternal problems with high oil consumption. Yes, the valve guides dropping down in the head were a bigger contributor, but even with the guides fixed the 3.0 was prone to being a blue smoker because of the ring package and narrow ring lands on the piston. |
