AFTER MARKET!connecting rods
https://slantsix.org/forum/viewtopic.php?t=21603
Author:  Mister Twister [ Thu Jan 25, 2007 5:18 am ]
Post subject:  AFTER MARKET!connecting rods
Looking for makers for my 225/ project thanks for any help you can give me http://www.stormcomm.net/donsduster.htm
Author:  Matadem [ Thu Jan 25, 2007 12:49 pm ]
cox bros
about $1000 a set
Author:  Dave M [ Thu Jan 25, 2007 4:14 pm ]
Last set I bought was from Cunningham $1100.00
Any rod any lenght steel or titanium
Author:  Ron Parker [ Thu Jan 25, 2007 4:40 pm ]
Is this a bat out of hell Slant drag car if not why do you want custom rods. Thanks Ron Parker :D
Bagels On Juice Im On Boost
Author:  Mister Twister [ Tue Jan 30, 2007 3:04 am ]
Hay Ron no just a weekender and local MOPAR shows
have to keep up with dodgegirls v8 Twister mid 13 will be fine :twisted:
Author:  Ron Parker [ Tue Jan 30, 2007 4:28 pm ]
Stock rods should be fine . Unless you are shooting at 400 or better horses. Bagel runs 198 rods on his juice bomber and has went 12.01 and had no rod isues. I run 198 rods and go like 12.50 and not a issue. Just have your machineist i think the term is to recondition them or refurbish them and you should be fine. Remember good parts in a engine will last longer and be more cost effect than cheap parts to do the same thing.Thanks Ron Parker
Bagels On The Juice Im On Boost
Author:  Mister Twister [ Sat Feb 03, 2007 3:20 am ]
thanks Ron found 2 198 rods still need 4 more to get block together 225 RODS TO SHORT FOR THE PISTONS I GOT fla to cal not having to much luck any Ideeeeeas!
