| Oil pump gear removal https://slantsix.org/forum/viewtopic.php?t=21635 |
| Author: | Bren67Cuda904 [ Sat Jan 27, 2007 5:31 pm ] |
| Post subject: | Oil pump gear removal |
![]() Where can I get one of these pullers to remove a gear or can it be done with a simple 12 ton press? |
| Author: | Bren67Cuda904 [ Sat Jan 27, 2007 5:41 pm ] |
When reinstalling the gear I read to heat the gear and freeze the shaft. How hot to heat the gear? I don't want to get it to hot with the torch. |
| Author: | Doctor Dodge [ Sat Jan 27, 2007 7:04 pm ] |
If your shaft / gear has a keyway, you must use a puller. I use a toster oven to heat my gears, 400 degrees is about right. DD |
