It is currently Fri Nov 20, 2026 4:06 am
PostPosted: Mon Feb 05, 2007 6:19 am
Help!! Could somebody give me a clue on what throw out bearing to use when installing my T-5. The T-5 I've got is out of a 95 Mustang 5.0.
PostPosted: Mon Feb 05, 2007 5:49 pm
I Belive Lou Uses a t-5 With a Hydro TO Bearing - Pm user name dart270
Sam Powell also uses a t-5 - not sure on the TO bearing there.
I believe Sam Powell is his ser name.
PostPosted: Mon Feb 05, 2007 6:19 pm
EFI slant 6, thanks for the reply. I'm using the stock clutch fork, actuated by a hydralic slave cylinder. So I think I will need a throw bearing that will work with the stock fork. I'm building a track-T roadster, so everything is one off. It's got a sixty over 225 w/ 3 sidedraft webbers and a crane hydraulic cam. Something different from the normal track-T's
PostPosted: Mon Feb 05, 2007 7:53 pm
Randy I used a stock Valaint throwout bearing on my 5 speed swap (not T5),,,,I machined the Mustang imput bearing retainer to fit ,,,,used the stock Valiant arm and bell and linkage and pressure plate.....Mustang disc.
7 years ....50,000 miles
PostPosted: Tue Feb 06, 2007 6:58 pm
[quote="sandy in BC"]Randy I used a stock Valaint throwout bearing on my 5 speed swap (not T5),,,,I machined the Mustang imput bearing retainer to fit ,,,,used the stock Valiant arm and bell and linkage and pressure plate.....Mustang disc.
7 years ....50,000 miles[/quote]
[quote] Sandy thanks for the info. I'll mike my bearing retainer and see if
this can be done. Sure would make it simple. Thanks again Randy[/quote]
Users browsing this forum: Bing [Bot] and 5 guests
