| Backcut valves https://slantsix.org/forum/viewtopic.php?t=21665 |
| Author: | Hyper Kevin [ Tue Jan 30, 2007 9:48 am ] |
| Post subject: | Backcut valves |
I'm running a Super 6, MP 243 cam right now. Other than a 2.25 single exhaust and maybe a .060 mill, I don't plan on any other performance mods in the next few years. Would standard size backcut valves make a noticeable difference on a mild build-up like this? |
| Author: | slantzilla [ Tue Jan 30, 2007 10:02 am ] |
Probably not. |
| Author: | Hyper Kevin [ Tue Jan 30, 2007 10:21 am ] |
At what point do backcut or oversized valves become a worthwhile improvement? I apologize for my ignorance on this subject, but I figure this is the one place where I can get an honest answer. |
| Author: | slantzilla [ Tue Jan 30, 2007 10:58 am ] |
I always see it as the final touch of a good porting job. It helps get the last possible bit of improvement from other mods, but does very little on it's own. |
| Author: | Hyper Kevin [ Tue Jan 30, 2007 12:46 pm ] |
Thanks. It sounds like my local "mopar expert" steered me wrong. |
| Author: | Doc [ Tue Jan 30, 2007 3:43 pm ] |
The key here is some basic head "pocket porting" combined with the oversize valves. Port the head, mill it for some added compression and install oversize valves and you will notice a performance improvement. To install O/S valves with-out doing the basic porting work needed to open up the area directly under the valve seat, is a waste. DD |
