It is currently Wed Nov 18, 2026 12:01 pm
PostPosted: Wed Dec 13, 2006 11:56 am
Just joined the org about 3 minutes ago, but a longtime reader. Now I feel legit. I am attempting a four-speed A833 into a 67 Barracuda /6 in order to make an engine swap more interesting. I have the small 8 bellhousing that came with the trans, the A903 b.h., and a /6 four-speed b.h. with a 5.125 IBR circle. Naturally, the 833 I have has the smaller bearing/ flange IBR combo. Any adaptors available?javascript:emoticon(':|')
/6 '67 Barracuda convertible, electronic ignition, 4-OD, street cam, SBP KH discs, 3.55 SG 7.25" 1" t-bars. Bilstein.
340 '67 fastback, Doug Nash 5-speed.
1988 Toyota pickup work truck
PostPosted: Thu Dec 14, 2006 12:30 pm
Try this.
http://www.brewersperformance.com/products.asp?id=83
'15 Chrysler 200S V6
'74 Duster 360, factory 4 speed car
PostPosted: Thu Dec 14, 2006 2:15 pm
Thanks DionR. It looks like Brewers has a retainer adapter ring to match the 4.354" bearing retainer to the 4.805" bellhousing opening, in case anyone needs one of them. The opening in this one is 5.125 in what I think is a four-speed O.D. bellhousing, An adapter ring seems like the economical way to go.
PostPosted: Thu Dec 14, 2006 3:54 pm
Your right, my mistake. I was thinking there were only two sizes, guess there are three.
My apologies. :oops:
Perhaps "roll your own"?
Here's an article that talks about just what you are asking.
Maybe that will help more than my earlier suggestion.
PostPosted: Sat Dec 16, 2006 11:15 pm
You probably could get a machine shop to make you a spacer. It may be possible the change the front case with a new case from Passion Performance that had a retainer of this size. I am not sure they have one that will take a retainer this size because there site seems to be down at the moment. As soon as the site is up I will look into it.
Jess
PostPosted: Tue Jan 30, 2007 11:53 am
Passon makes a 5.125" OD adapter ring for $39. I've not seen it in their online catalog, so it must be one of those miscellaneous parts they stock. Jamie at Passon offered one to me via email, so that's how I came to find out.
What I don't know is if they have one for both the 4.35 and 4.80 bearing retainers, or if you would have to buy a 4.80 bearing retainer to go along with the adapter ring to make this work.
I gave you a faulty answer previously, so thought I would try and make up for it.
For all I know, it might be too late any ways.
