| Performance Clutch? https://slantsix.org/forum/viewtopic.php?t=21670 |
| Author: | 64Valconvt [ Tue Jan 30, 2007 1:13 pm ] |
| Post subject: | Performance Clutch? |
I know someone out there has answers or ideas on what sort of performance clutch I can use, thanks for the help, -Steve |
| Author: | Doc [ Tue Jan 30, 2007 3:58 pm ] |
Here is some information. http://www.slantsix.org/articles/clutch ... utches.htm You may need to call around for current availability on some of the units discussed. Also try to search the old messages, there have been some good threads on this subject. DD |
| Author: | sandy in BC [ Tue Jan 30, 2007 5:04 pm ] |
The clutch with your "three on the tree"is a fair match for your trans. Putting a stronger clutch in your car will simply make your fragile trans the weak link. I use a 9.25 clutch in my car but use a Turbo T bird disc that matches my 5 speed trans. If you are slipping the clutch because your gear ratios or driving style are inadequate a larger clutch will not fix the problem. If you wish to upgrade the clutch it makes sense to upgrade gears and trans. ie 4 speed 833 and 10"clutch with 3.23 gears OR 4 speed 833OD 10"clutch 3.91 gears |
