It is currently Sat Nov 21, 2026 3:44 pm
PostPosted: Fri Feb 02, 2007 9:01 am
I've started a topic on my fuels forum entitled Ultimate LPG Fuel Economy, in which I was trying to find out if there is a lean fuel ratio that maximizes fuel economy while not being prone to lean misfire. One of the ideas that I had in mind with this topic was Chrysler’s Electronic Lean Burn system. While ELB may not have worked all that well in practice, I think the concept probably had some good research data behind the design.
I think the concept was to improve fuel economy by reducing the pumping losses in their engines. As most of you are probably already aware, a slightly rich fuel mixture produces the maximum amount of power in a spark ignition engine while a slightly lean fuel mixture produces the best fuel economy. As the fuel mixture becomes progressively leaner, the throttle must progressively open more to maintain the same power output. Although the engine's thermodynamic efficiency drops (due to lower combustion temperature) with leaner fuel mixtures, its mechanical efficiency increases because the flow restriction across the throttle becomes smaller. I think Chrysler was trying to push the optimum lean mixture envelope with their rudimentary spark advance computer.
Does anyone have any information from Chrysler regarding the thought that went into the ELB? I think this information would useful for people setting up their MegaSquirt systems for either gasoline or propane.
PostPosted: Sat Feb 03, 2007 4:40 am
I've heard that when Honda later tried the concept on their '90s era Civic VX, which used injection and a wideband sensor, they aimed for somewhere around 16:1 under cruising - maybe even leaner. Ultimately that got forced off the road by emissions laws, but it's a rare slant that has to meet the same emissions standards as a 1992 Civic.
Most of the accounts I've read about Lean Burn blame two things for its problems: The large amount of vacuum hose, and mounting the computer on the air cleaner instead of inside the passenger compartment.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Sat Feb 03, 2007 6:48 am
I do have a bunch of the development papers on ELB. What I don't have at the moment is time to photocopy or scan them. If you can give me some time, I can share 'em.
And yes, Honda and others have run 16:1 or leaner on gasoline under cruise. In fact, SDS recommends running at such ratios under cruise conditions to save on fuel.
