| Bbd I.d.? https://slantsix.org/forum/viewtopic.php?t=21729 |
| Author: | Rug_Trucker [ Sat Feb 03, 2007 10:34 am ] |
| Post subject: | Bbd I.d.? |
I have at least 3 BBD's. One junk yard piece off a 73 318, one I bought for $10 that was shiney and fresh looking. They both have plastic vent fittings. The other is maybe a "tin top?" I am taking it apart and taking pics as I go. I has an idle screw broke off in it. Where it came from I can't remember. Tell me oh "BBD GUHRU'S!!!" |
| Author: | DusterIdiot [ Sat Feb 03, 2007 1:42 pm ] |
| Post subject: | Casting number? |
if the carb doesn't have a tag anymore, then look on the side of the body for a casting number/etc..., one of us might have that information.... -D.Idiot |
| Author: | SlantSixDan [ Sat Feb 03, 2007 1:43 pm ] |
Not nearly enough info. How 'bout some pictures or tag numbers? |
| Author: | Rug_Trucker [ Sat Feb 03, 2007 4:46 pm ] |
Quote: Not nearly enough info. How 'bout some pictures or tag numbers?
No tags. They have numbers on the bottom of the throttle bodies. And they have numbers on the passenger side of the fuel bowls. What number you need?
| Author: | SlantSixDan [ Sat Feb 03, 2007 5:06 pm ] |
Casting numbers are no good, they can't be used to ID the carb application since the same castings were punched out and machined a bunch of different ways for different carbs. Pictures! |
| Author: | Rug_Trucker [ Sat Feb 03, 2007 7:14 pm ] |
carb #1- 2285 on the throttle plate carb upside down 0-2361 fuel bowl plastic bowl vent fitting #2 2759 TP 2361-0 bowl yep this is how the zero showed! plastic bowl vent fitting This was on a '73 318 truck. #3 2466 TP 0-2543 bowl big metering rods and jets Tin top? Looks different. I don't see how to attach pics here. I have lots of pics |
| Author: | 64'4$peed [ Sat Feb 03, 2007 7:23 pm ] |
I've got a BBD with a plasitc bowl vent on my car right now. wont idle below 1,000 rpm's but runs great. |
| Author: | SlantSixDan [ Sat Feb 03, 2007 8:08 pm ] |
Photo instructions are Here |
| Author: | Rug_Trucker [ Tue Apr 24, 2007 8:27 pm ] |
Just picked up another BBD. This one has no bowl vent lever. The tiny rods and jets like the 2361 carb. It has no way to attach an air cleaner, no egr fittings. Just PCV, vac advance, and choke pull off. Casting number is 0-1676. $5 carb from the swap meet. |
| Author: | dakight [ Tue Apr 24, 2007 8:55 pm ] |
Some of the early 273 cid V8 motors uses a screw clamp to attach the air cleaner to the air horn of the carburetor; that might be what you have. |
| Author: | SlantSixDan [ Tue Apr 24, 2007 9:04 pm ] |
Quote: Just picked up another BBD. This one has no bowl vent lever. The tiny rods and jets like the 2361 carb.
That's a '64-'65 BBD for a 273 or 318. 1966 was the first year on BBDs for the bail-and-wingnut air cleaner attachment you're used to seeing; prior to '66 the air cleaner had a jackscrewed clamp band that clamped onto the outer diameter of the air horn.
It has no way to attach an air cleaner, no egr fittings. Just PCV, vac advance, and choke pull off. |
