| Throw out Bearing for T-5? https://slantsix.org/forum/viewtopic.php?t=21753 |
| Author: | Randy Nelson [ Mon Feb 05, 2007 6:19 am ] |
| Post subject: | Throw out Bearing for T-5? |
Help!! Could somebody give me a clue on what throw out bearing to use when installing my T-5. The T-5 I've got is out of a 95 Mustang 5.0. |
| Author: | Greg Ondayko [ Mon Feb 05, 2007 5:49 pm ] |
I Belive Lou Uses a t-5 With a Hydro TO Bearing - Pm user name dart270 Sam Powell also uses a t-5 - not sure on the TO bearing there. I believe Sam Powell is his ser name. Greg |
| Author: | Randy Nelson [ Mon Feb 05, 2007 6:19 pm ] |
| Post subject: | Throw Out Bearing For T-5? |
EFI slant 6, thanks for the reply. I'm using the stock clutch fork, actuated by a hydralic slave cylinder. So I think I will need a throw bearing that will work with the stock fork. I'm building a track-T roadster, so everything is one off. It's got a sixty over 225 w/ 3 sidedraft webbers and a crane hydraulic cam. Something different from the normal track-T's |
| Author: | sandy in BC [ Mon Feb 05, 2007 7:53 pm ] |
Randy I used a stock Valaint throwout bearing on my 5 speed swap (not T5),,,,I machined the Mustang imput bearing retainer to fit ,,,,used the stock Valiant arm and bell and linkage and pressure plate.....Mustang disc. 7 years ....50,000 miles |
| Author: | Randy Nelson [ Tue Feb 06, 2007 6:58 pm ] |
| Post subject: | Throw out bearing for T-5? |
[quote="sandy in BC"]Randy I used a stock Valaint throwout bearing on my 5 speed swap (not T5),,,,I machined the Mustang imput bearing retainer to fit ,,,,used the stock Valiant arm and bell and linkage and pressure plate.....Mustang disc. 7 years ....50,000 miles[/quote] [quote] Sandy thanks for the info. I'll mike my bearing retainer and see if this can be done. Sure would make it simple. Thanks again Randy[/quote] |
