| What tool to remove fill plug from 7 1/4? https://slantsix.org/forum/viewtopic.php?t=21805 |
| Author: | Daedalus [ Fri Feb 09, 2007 4:14 pm ] |
| Post subject: | What tool to remove fill plug from 7 1/4? |
I'm trying to figure out what tools I need to remove the fill plug from my diff. I think it is a 7 1/4. I'm used to using a 1/2" extension to remove the plug, but this looks like some kind of Torx bit or something. |
| Author: | Doc [ Fri Feb 09, 2007 4:26 pm ] |
Yes, the 1/2 square should do the job. Call it an "8 point" socket, basically two, 1/2 squares shapes, off-set and super-imposed on each other. |
| Author: | SlantSixDan [ Fri Feb 09, 2007 4:27 pm ] |
Threads here and here. |
| Author: | Ron Parker [ Mon Feb 12, 2007 4:35 pm ] |
On a 8 3/4 that is easy I use a Alabama speed wrench. Bagels On Juice Im On Boost |
| Author: | Daedalus [ Thu Feb 15, 2007 7:50 pm ] |
Doh! I *knew* I should have taken my tools under there and tried it. I suppose that's what I get for my laziness. Black soup has been drained out and full synthetic 85w/140 has been filled... Thanks... |
