It is currently Fri Nov 20, 2026 8:11 am
PostPosted: Wed Jan 17, 2007 5:23 am
I am trying to buy this from another site, but just wanted confirmation that it is indeed a 4 speed bellhousing for a slant 6. If anyone can confirm this i would appreciate it. Thanks ,Evan
http://www.jalopyjournal.com/forum/show ... p?t=151966
 Post subject: Loooks like one...
PostPosted: Wed Jan 17, 2007 6:08 am
I would ask about the size of the bearing retainer hole, if it's a 5.125" it's not that rare.... also a pic of the other side would help date the bell as the truck ones have a ball stud and the car versions use a plate with a hole stamped in it.
PostPosted: Wed Jan 17, 2007 8:09 am
Visually, it looks identical to my 5.125 BR bellhousing. Fork pivot bolts are spread pretty far apart, which happened when they went to the big bearing retainer.
The fork looks like it's the early non ball stud style bell.
Definitely not that rare. I think $80 is way out of line, $45 with the fork might be more reasonable.
Check out carpart.com, I remember seeing some for $35 or less, but that might not be with the fork.
'15 Chrysler 200S V6
'74 Duster 360, factory 4 speed car
 Post subject: bell housing
PostPosted: Wed Jan 17, 2007 8:12 am
where is the ball stud located? Can i use the truck bell housing in my valiant convert? Thanks for the quick response. Evan
PostPosted: Wed Jan 17, 2007 12:58 pm
Not rare - I have 3 of those.
It will Mout the 833 and the 230 3 Speed with the Proper 5.XXXX Baering retainer.
You can find those on ebay cheaper than 45 every week. Die cast aluminum constuction - with 3 Tranny Mouting Patterns on it.
Even though it might Be a truck piece it will work in a car you could drill and tap the bosses for the clutch piviot, but I would get one that is complete and right for your application.
Again Weekly on ebay.
PostPosted: Wed Jan 17, 2007 4:07 pm
Best I can tell, it's not a ball pivot type housing. The bolt holes for the early plate style pivot are there (all though, they could be undrilled as was pointed out earlier), and I would think a hole for the ball pivot would show on the trans side, which it doesn't. Also, I would think the fork would have a divot for the ball, rather than a "ditch" for the plate style. Just my observations.
Would it matter if it was a ball pivot, though? Seems like the ball would give you the option to set you pivot height easily. Just a thought.
BTW, the ball (or plate) pivot is on the inside of the bell housing, on opposite face of the bell where the trans bolt on. It's what the clutch fork pivots on when you release the clutch. If you look at the picture, there is an extra bolt hole very close to the large hole in the middle. That is the bottom bolt hole for the pivot plate.
 Post subject: Dion, I have 4, PM me
PostPosted: Thu Jan 18, 2007 2:06 pm
Dion,
As others say, not rare. I have 4 left from the great truck project and the T% deal. PM me.
rock
64d100
PostPosted: Thu Jan 18, 2007 3:42 pm
Dion,
As others say, not rare. I have 4 left from the great truck project and the T5 deal. PM me.
rock
64d100
Thanks, but I'm not looking for one. :D
I've got a BH already, plus my adapter plate from Novak to adapt my R154 to the /6.
Sorry to hear you got stuck with extras, though.
PostPosted: Fri Jan 19, 2007 2:54 pm
I think Fargoguy is the one looking for the Bellhousing.
Honest mistake.
PostPosted: Tue Feb 13, 2007 6:14 am
Fargoguy, you have a PM.
If a MedAlert bracelet is the only bling you wear......You might be getting old.
Users browsing this forum: Amazon [Bot] and 4 guests
