It is currently Sun Nov 22, 2026 1:38 am
 Post subject: what size, more torque
PostPosted: Mon Feb 12, 2007 12:03 pm
I have a "63" D200 short box step side with a slant 6, 727 auto, dana 60 and am not sure what the engin size is. It started life as a US forestry fire fighting truck, so I assume its a 225? Will the casting number on the block , below the intake tell me anything? It only shows 77000. I havent decided if Im going to keep it or sell it. If I keep it I would like to up grade the motor to get alot more torque out of it because Im thinking it has some pretty low gears in it. I would be useing it to tow a car trailer as I buy old cars [mopar] to junk for parts or restore. I am allso thinking of customizing this truck, buts thats down the road for now. Help! kelly
    PostPosted: Mon Feb 12, 2007 12:25 pm
    Car Model: 71 Dodge D100 64 Plymouth Valiant Wagon
    Kelly---
    Sounds like a good candidate for a poly 318, actually. Check out www.sweptline.org for a treasure trove of info on your truck, and prospective buyers if you want to sell it.
    Joe
    Joe Hoppe
    71 D100 225 Super Six 727 AT on 2008 Crown Vic CopCar frame
    64 Valiant Wagon 225 904 AT 3:23 8.75"
    PostPosted: Mon Feb 12, 2007 5:41 pm
    Ive got a "73" 318 that I could put in it, but I thought it would be cool to keep it original sortof
    PostPosted: Mon Feb 12, 2007 6:56 pm
    welcome to the forum. One of the best upgrades for your dollars worth is supersixing it (if its not already). That is installing a two barrel intake and carb. Along with that would be to upgrade to a bigger exhaust to get the most of the supersix. There are alot of other mods to be done (some are not even that expensive) such as recurving the distributor, other members will give you more advice. There is alot of info on this forum.
    Excuse me, does this smell like chloroform to you?
