| Bright, Dim, Bright Dim https://slantsix.org/forum/viewtopic.php?t=21838 |
| Author: | DusterBuster [ Mon Feb 12, 2007 6:07 pm ] |
| Post subject: | Bright, Dim, Bright Dim |
Hey i got an electrical problem sumwhere...well atleast i think its an electrical problem...for sum reason"just recently" my lights will dim ALOT when i stop an idle and then when i take off they get bright again |
| Author: | 74W100/6 [ Mon Feb 12, 2007 6:26 pm ] |
| Post subject: | lights |
Well if your car is a manual i think i know what the problem is, as i went through this in my pickup. Everytime i push the clutch in the lights got brighter, BECAUSE my chassis was not grounded, thus when i pushed in my clutch, it created a stronger ground to my dash. Perhaps your situation is somewhat the same...i would check all my grounds and make sure your chassis and body are grounded. |
| Author: | DusterBuster [ Thu Feb 15, 2007 10:45 am ] |
Mine is an automatic..but i do see similar results when i tap the brake. Thanks ill take a look at all the grounds this weekend! |
| Author: | Lars [ Thu Feb 15, 2007 4:20 pm ] |
Also check to see how well it is charging. Take a multimeter while the engine is idling and check the voltage on the battery. It should read right around 14.3 volts at the battery. |
