| 833 Trivia question https://slantsix.org/forum/viewtopic.php?t=21866 |
| Author: | Greg Ondayko [ Wed Feb 14, 2007 11:38 am ] |
| Post subject: | 833 Trivia question |
Hello Folks; What years Did The 833 Come from the factory with the Small Splined output shaft (Like a 904 or light duty 3 Speed)? So far I have seen 2 of them; one was an early model - probably 65 0r 66, and the other one is an all aluminum model, including the side cover everything is aluminum except the Bearing retainer. The first correct answer gets to choose 833's for $400! Thanks, Greg |
| Author: | Ron Parker [ Thu Feb 15, 2007 4:07 pm ] |
1963 Thanks Ron Parker Bagels On Juice Im On Boost |
| Author: | slantzilla [ Thu Feb 15, 2007 4:33 pm ] |
The aluminum one is prolly an OD from a pickup. The one in my '83 pickup had a small output. |
| Author: | Greg Ondayko [ Thu Feb 15, 2007 5:18 pm ] |
Ron, I am not disputing your answer here, but I was under the impression that the 63 Boxes would still have the Flange for the ball and trunion Setup - Is that not The case??? Please educate and advise - Thanks, Greg |
| Author: | Moljnir [ Thu Feb 15, 2007 6:36 pm ] |
65 was the last year for ball and trunnion A833's, in A bodies. The longer A833's cropped the ball and trunnion a year earlier. As for what years had the small spline ouput, dunno. Steve |
| Author: | DusterIdiot [ Thu Feb 15, 2007 8:22 pm ] |
| Post subject: | In other cases... |
Quote: 65 was the last year for ball and trunnion A833's, in A bodies. The longer A833's cropped the ball and trunnion a year earlier. As for what years had the small spline ouput, dunno.
I have heard from a couple of local 'old timers' that some very-early 1966 manufactured cars even got the last of the B&T A-833 trannies too...This is typical for mopar in many cases where "goofy things happen"(or aka. 'we found a palate in storage, here use these up!'), or like the 3 different rear seals for the A-230 that changed between early 1972-1976...some A-833OD's have been splined to use the A-904 style yoke, and some late A-230's were splined to use the 833/727 yoke...it's enough to really muck up a day when pulling a tranny apart if you aren't paying attention... -D.Idiot |
| Author: | Romeo Furio [ Fri Feb 16, 2007 1:56 pm ] |
| Post subject: | tranny |
Checked with Passon, 66- 67 A body only 76- 78 A&F body overdrive |
| Author: | Ron Parker [ Sat Feb 17, 2007 7:48 pm ] |
Well I lost that one . But I like playing MOPAR Jeperody. Thanks Ron Parker Bagels On Juice Im On Boost |
