It is currently Sun Nov 22, 2026 4:16 pm
 Post subject: rocker arms
PostPosted: Wed Feb 14, 2007 10:10 pm
i have 74 duster with a 225 what is the best way to adjust the rocker arms ???
PostPosted: Thu Feb 15, 2007 6:10 am
Look HERE for a discussion.
I set mine 0.010" and 0.020" (intake and exhaust), hot and running.
PostPosted: Thu Feb 15, 2007 1:22 pm
is there other way than runing the engine
 Post subject: adj rockers not running
PostPosted: Thu Feb 15, 2007 2:21 pm
you have the the #s on last post here is how! put your finger on intake rocker over valve spring turn motor over till your finger is all the way down then adj exaust rocker to spec move your finger to exaust rocker next to the one you adjusted and repete adj down the line hope this helps you
'72 Image Duster /6 with turbo build up
'03 Ram 2500 4x4 w/HEMI 5sp 4:10 posi
My Twister Page
