| engine size https://slantsix.org/forum/viewtopic.php?t=21898 |
| Author: | kellydeec [ Fri Feb 16, 2007 6:25 am ] |
| Post subject: | engine size |
What are the different block casting numbers to determine the engine size on a 63 truck |
| Author: | terrylittlejohn [ Fri Feb 16, 2007 7:23 am ] |
the engine size is on the lip of the block just be hind altenator if the block has never been machined although i did disassemble a 225 stamped block to fined it was a 198. |
| Author: | slantvaliant [ Fri Feb 16, 2007 9:29 am ] |
As terrylittlejohn said, the stamped number is right here, ![]() unless the block has been machined. Between and below #1 and #2 plugs, beside the coil. As I understand it, 198's and 225's use a common block. The cranks and rods make the difference. 170's have a different block. Check out Doug's articles on BLOCKS and STROKERS |
