| Parts hoarding before Chrysler goes over the side https://slantsix.org/forum/viewtopic.php?t=21904 |
| Author: | paul_sak [ Fri Feb 16, 2007 7:22 pm ] |
| Post subject: | Parts hoarding before Chrysler goes over the side |
With Chrysler in trouble again Here is my tentative list.... gasket for fuel outlet/sending unit bolts for ring gear (for 7 1/4 diff) window rivets What is on your list? |
| Author: | Pierre [ Fri Feb 16, 2007 10:58 pm ] |
| Post subject: | Re: Parts hoarding before Chrysler goes over the side |
The round flat ring? Availible aftermarket.What is on your list? I wonder what they'll do with the parts. |
| Author: | Eric W [ Sat Feb 17, 2007 12:14 am ] |
Here is a link to Moparts with a list of whats still available. I think I posted this a long time ago, but here it is again. http://board.moparts.org/ubbthreads/sho ... ost2239174 Don't know how accurate it is anymore, take it for what its worth. I got an electronic ignition harness today from my local Dodge dealer, so you can still get those. |
| Author: | ROADRUNNER7169 [ Sat Feb 17, 2007 7:12 am ] |
nothing has changed yet in parts (im a mopar parts dealer) as for part # if anyone has a list of parts #'s they want me to check i will gladly do so as for the fuel tanksending unit seal thier is about 200 still availible and the current part # on it is 3404451 and on the ring gear bolt their are about 50 at the depo's I evin have them in stock the part # is 4443158 and on the window to regulator rivits the part # is 6023546 and thier are about 26 of them left hope this helps you out |
| Author: | ceej [ Sat Feb 17, 2007 4:55 pm ] |
Spark Plug Tubes? That and maybe some Muffler Bearings. I can't stand a squeaky exhaust! CJ |
| Author: | Eric W [ Sat Feb 17, 2007 10:31 pm ] |
Quote: Muffler Bearings. CJ |
| Author: | oldgoat83 [ Tue Feb 20, 2007 2:42 pm ] |
Quote: Spark Plug Tubes?
Couple of quarts of Quaker State should fix that right up.
