It is currently Mon Nov 23, 2026 10:05 am
 Post subject: Rocker shaft questions
PostPosted: Mon Feb 19, 2007 2:43 pm
I keep reading that the last rocker shaft bolt and it's hole a different than the rest but on my engine, there isn't a stepped bolt, there is one bolts that is shouldered, and longer, I assume it is the rear. also the holes are all the same size. the oil holes point towards the valve spring right. But the rockers slide in front of the holes. Any differences in the half moon "washers" or can they go anywhere?
.020 off the block .100 from head
Comp 264
904 Tranny
New Ebre-ting
http://s78.photobucket.com/albums/j103/edrod01/
 Post subject: rocker bolts
PostPosted: Mon Feb 19, 2007 3:31 pm
the older heads had the long 3/8 bolt and the newer heads had the 5/16 tappered bolt in the rear hole as for washers there are 2 that are wider than the others
 Post subject: Kind of...
PostPosted: Mon Feb 19, 2007 3:47 pm
I have found the Tapered bolt in the late 1978 and 1979 heads, and my two '76 heads had the regular 3/8" bolt( as well as my drool tube heads)...Maybe Dan knows the machining cutoff date for this oddity...
Users browsing this forum: Google [Bot] and 11 guests
