It is currently Fri Nov 20, 2026 10:32 pm
 Post subject: rear end
PostPosted: Thu Feb 22, 2007 11:46 am
i have a guy that is will to sell me a 8 3/4 3.91 posi rear end from a 64 a100 van what i am wondering if it will fit on my 74 duster thanks for the help :bow:
PostPosted: Thu Feb 22, 2007 7:58 pm
You could always have it narrowed for around $150 or so. Sometimes it's easiar to cut to length. But then again, you would have to order custom length axles. ($350 or so).
PostPosted: Thu Feb 22, 2007 9:13 pm
If it is anything under $350.00, get it just for the 3.91 Sure Grip.
The Van's housing and axles are not anywhere close to what you need for your A-Body.
 Post subject: Rear
PostPosted: Fri Feb 23, 2007 7:09 am
350.00 is a great price for the pig alone. should be a 741 case with a V ramp sure grip. Go for it........
 Post subject: Rear end
PostPosted: Fri Feb 23, 2007 9:24 am
I have seen elsewhere, that a 741 isn't very strong. Is this fiction or fact?
bwhitejr
'72 Duster (Performance 360)
'83 Ramcharger (Performance 318)
'80 TrailDuster (360)
'80 D-150 Truck (See Below)
CompCams 252S, Holley 390cfm, Offy manifold
Ported, Polished and Gasket Matched
P4286813 Springs,0.040 Overbore,
0.090 Shaved Head
 Post subject: Not totally true...
PostPosted: Fri Feb 23, 2007 9:34 am
The 741 is fine behind the mild hauling truck, slant six, 318 poly, 383-2v etc... where this myth started was the crowd that would pull a 30 year old open 741 diff and plant a 1000+ hp blown hemi in front of it and have it whither on the bark of the tires...
3.91 sure grip 741 is about $350 at the Oregon swap meets, the hard part will be finding an A or B -body 8 3/4 housing and axles...
PostPosted: Sat Feb 24, 2007 5:41 am
I run a 741 case with 4.30 gears in a 13 second Dart 2900 lbs for 5years now. Also run one in a 65 Belvedere 11 seconds 3600 lbs for 3years
741 get a bad rap because of the 3 cases it has the smallest pinion size 1 5/8 inch. 742 case 1 3/4 inch. 489 case 1 7/8 inch. I think that is correct sizes but don't quote me on it. Should live behind a slanter...
PostPosted: Sat Feb 24, 2007 6:19 am
As DD says,
I would jump on it for the pig alone at that price. I got a 489 case pig for what I thought was a good price, rebuilt .....$550.00, good for "down south" Before installing it I ran a non posi 3.91 in a 741 case in my truck for 30 years without a hint of problem. Just wanted the posi and the 489. Obsession, ya know.
rock
'64d100
Users browsing this forum: DuckDuckGo [Bot] and 2 guests
