It is currently Tue Nov 24, 2026 8:36 pm
 Post subject: Resealing a Slant 6
PostPosted: Sun Feb 25, 2007 3:44 pm
I've been thrashing around for 2 weeks now thinking I needed replacement engine, because the one in my truck is surely tired, uses oil and the oil light kept coming on. I replaced the oil pressure sender and the oil light problem seemed fixed, but I was still suspicious that the motor needed replacing. Until I plumbed an oil pressure guage onto it yesterday. This engine holds 55 pounds of oil pressure at anything abocve idle, and when hot maintains 40 at idle in drive. So now I think I could just reseal the motor to solve the oil consumption problem, because I think it leaks more than it burns. Is there anything special I need to know about resealing a slant? Here are some questions:
-I want to put a timing cover crank seal in it, so how does the balancer come off? Does it have a retaining bolt or is it a tap-on deal like a 250 cheby?
-I'll pull the engine out when I do it, so I'll put a oil pan gasket set in it. But what about the rear main seal...any hints/tips there?
-Where else does the slant tend to leak?
-I don't know what year vintage my motor is, is there a way to tell year of manufacture so I know what gaskets to buy?
Thanks. Davey
PostPosted: Sun Feb 25, 2007 4:50 pm
See this article.
http://www.slantsix.org/articles/gasket ... n-seal.htm
PostPosted: Sun Feb 25, 2007 6:07 pm
The balancer is pressed on, you need a puller to remove it. Any year gasket set will work, they are all the same with exception of the aluminum engine.
PostPosted: Sun Feb 25, 2007 8:04 pm
is the balancer just warmed in the oven and tapped back on?
PostPosted: Sun Feb 25, 2007 8:12 pm
All you need is a universal balancer tool. They can be rented at just about any auto parts store with a small down payment. Use it, return it, and get your down payment back. :D
PostPosted: Mon Feb 26, 2007 5:46 am
It is not necessary to heat the balancer. The end of the crank is drilled and tapped. Just use a balancer installer tool, or a bolt to draw it on. Do not drive it on with a hammer.
PostPosted: Tue Feb 27, 2007 5:38 am
What size thread bolt Charlie? MY A/C belt snapped and removed my timing tab. :shock: I need to do a swap someday.
PostPosted: Tue Feb 27, 2007 10:13 am
What size thread bolt Charlie? .
3/4-16 Not sure what length will work. I have several different lengths, just for that. You will also need at least one large flat washer.
PostPosted: Tue Feb 27, 2007 11:43 am
Pullers are dirt cheap check Harbor Freight etc. Everyone sells the cheap junk.
Users browsing this forum: Ahrefs [Bot] and 7 guests
