| how do you recreate the factory sealant in the trunk area https://slantsix.org/forum/viewtopic.php?t=22020 |
| Author: | redfivexw [ Sun Feb 25, 2007 5:58 pm ] |
| Post subject: | how do you recreate the factory sealant in the trunk area |
I am restoring the trunk area in my 74 dart, i had to remove some dried up seam sealer in a few areas, i am looking to recreate the factory look of the seam sealer, does anyone know the proper sealer to use and how to apply it to look factory? |
| Author: | BigBlockBanjo [ Sun Feb 25, 2007 6:40 pm ] |
I don't have the link, but I'm pretty sure that Eastwood has something that would work. Just google it, and you should find the site. I don't know the proper way to apply...but it doesn't look like they spent much time on it! Good luck! |
| Author: | SlantSixDan [ Sun Feb 25, 2007 6:47 pm ] |
Believe you are after this stuff. |
| Author: | redfivexw [ Mon Feb 26, 2007 5:04 am ] |
that stuff that eastwood sells looks more like paint, the stuff that dodge used seemed to be thicker, more rubbery. |
| Author: | SlantSixDan [ Mon Feb 26, 2007 9:00 am ] |
Eastwood have the rubbery stuff, too, as do your local auto body and paint supply store (where the body men go to get their paint and supplies). |
| Author: | slantvaliant [ Mon Feb 26, 2007 9:13 am ] |
Maybe THIS is what you're looking for? |
| Author: | AnotherSix [ Mon Feb 26, 2007 12:42 pm ] |
3m and ppg both make several and there are other brands as well. As Dan pointed out go to a auto body paint supply shop. Some come in cans, some in tubes for a chalking gun. The ones I have used are black, tan or white. Just make sure it is a paintable sealer if you ar going to paint over it. Eastwood has some great stuff but some of what they sell are normal body shop supplies and might cost quite a bit less if you source them that way. Quicker too if you can just go pick it up. |
| Author: | SlantSixDan [ Mon Feb 26, 2007 12:59 pm ] |
Quote: Eastwood has some great stuff but some of what they sell are normal body shop supplies and might cost quite a bit less if you source them that way. Quicker too if you can just go pick it up.
Yeah, what he said ↑ ↑ ↑
| Author: | redfivexw [ Mon Feb 26, 2007 1:42 pm ] |
Thanks for the tips. I have never used seam sealer before. I dont think this stuff comes out in a caulking gun, it is spread out about 2-3 inches wide, and it is pretty thick, it almost looks like it was sprayed on. I will check with my local body supply |
| Author: | ROADRUNNER7169 [ Mon Feb 26, 2007 1:49 pm ] |
I use the 3m fast seal part #08505 works good but you need a calk gun to use it |
