| oil pan? https://slantsix.org/forum/viewtopic.php?t=22028 |
| Author: | 64'4$peed [ Mon Feb 26, 2007 5:27 pm ] |
| Post subject: | oil pan? |
I'm building up a slant from a 69 dart to drop into my 64 valiant. will I run into clearance problems with the 69 pan? thanks J |
| Author: | Doctor Dodge [ Mon Feb 26, 2007 9:13 pm ] |
The 1960 - 66 pan is different from the 67 on up pans, the area between the sump and the front of the pan is longer. Oil pick-up tubes are also different so swap on the oil pan and pick-up tube from the 64 and you will be OK. DD
| Author: | 64'4$peed [ Tue Feb 27, 2007 12:01 pm ] |
awesome photo!! thanks Doug |
| Author: | cjh [ Fri Mar 02, 2007 4:50 am ] |
Its a good idea to make or install a windage tray in the sump, stops the oil pressure taking a dive on lefthand corners. |
