| Gas guage needle not working https://slantsix.org/forum/viewtopic.php?t=22035 |
| Author: | schiz [ Tue Feb 27, 2007 11:26 am ] |
| Post subject: | Gas guage needle not working |
I replaced the gas tank in my 71 Dart Swinger and replaced the sending unit with a used one. The used sending unit worked in the other car prior to removal. My gas gauge is till not working. Is it operated by a vacuum? My speedometer works but is sorta shaky. Any comments? Parts needed will also be a help. Thanks...Duane |
| Author: | SlantSixDan [ Tue Feb 27, 2007 12:09 pm ] |
| Post subject: | Re: Gas guage needle not working |
Quote: I replaced the gas tank in my 71 Dart Swinger and replaced the sending unit with a used one. The used sending unit worked in the other car prior to removal. My gas gauge is till not working.
The primary diagnostic to figure out what's going on here is to answer this question: Does your engine temperature gauge work, or is it dead, too?Quote: Is it operated by a vacuum?
No, there is no vacuum involvement in your instrument cluster. As mentioned in your previous post, go get the three books described in this post.Quote: My speedometer works but is sorta shaky.
Separate issue, fixes are here.
| Author: | KBB_of_TMC [ Tue Feb 27, 2007 2:13 pm ] |
| Post subject: | gauge |
Triple check that the new tank is well grounded - the little ground strap clipped to the fuel line often breaks or corrodes. |
| Author: | schiz [ Thu Mar 01, 2007 4:12 am ] |
| Post subject: | engine temperature gauge answer |
I checked last night and I noticed that the temp gauge didn't move along with the gas gauge. So to answer your question, the temp gauge seems to NOT work also. One of these days, my electrician buddy will stop over to assist.....I asked him last night. Duane |
| Author: | slantvaliant [ Thu Mar 01, 2007 7:08 am ] |
When both the fuel and temperature gauges are on the blink, the instrument voltage regulator is a good suspect. IVR REPLACEMENT and SOLID STATE UPGRADE |
| Author: | schiz [ Thu Mar 01, 2007 8:35 am ] |
| Post subject: | Great info....by the way... |
I'll print off what you linked to me and investigate. Seems pretty simple. As far as the instrument panel, I undid the screws holding the instrument panel in the dash but it didn't seem to want to come out all the way so I could see behind the panel. Am I missing a step I also need to take the dash cap/pad off to replace the trashed one. Will that get me access needed to get behind the panel? How hard is it to remove the pad properly vs placing one over the top? Many q's but you all seem to be the experts. Duane |
| Author: | SlantSixDan [ Thu Mar 01, 2007 8:40 am ] |
Do not tug/yank, you'll break stuff. The instrument cluster has to have both of its plug-on connectors removed, the speedometer cable has to be removed, and if your car has a gearshift on the steering column, the shift indicator string needs to be unhooked from the steering column sleeve. All of this takes place from underneath the dash. You will likely need to lower the steering column slightly by removing the bolts holding it to the underside of the dash. Then the instrument cluster can be lifted out of place and taken to a workbench for service. The instrument cluster voltage regulator can be replaced in a minute with a stock-type replacement from the parts store, or you can spend additional time and effort making up an electronic replacement. Got those books on the way yet...? |
| Author: | schiz [ Thu Mar 01, 2007 9:08 am ] |
| Post subject: | Books on the way... |
I ordered two of them just now on Amazon. One was way to high so I'll have to wait on that one. Ordered: --The Petersen automotive troubleshooting & repair manual by Petersen Publishing --Automechanics Fundamentals by Stockel, Martin Wall Thanks again for the quick replies.... |
| Author: | schiz [ Mon Mar 05, 2007 12:54 pm ] |
| Post subject: | speedo Update.... |
Well, my electrician buddy hasn't come over yet but here is what happened the other day with my speedometer. I was driving the car normal speed and all of a sudden the speedo jumped to 110-120 and making a weird buzzing sound. The weird thing is, after a small amount of time, the sound stopped and the speedo worked great with hardly a wiggle. It felt so good just cruising down the road knowing how fast I was going in peace. After a few miles (after I stopped at sign) it started again when I regained speed above 20mph or so. My wife said she smelt something but I didn't. Is my circuits in the back of speed burning up or am I just breaking my internals slowly? I will take my dash off eventually. Any advice for the mystery noise Thanks.......Duane |
| Author: | SlantSixDan [ Mon Mar 05, 2007 1:05 pm ] |
You definitely need to have your speedometer rebuilt. If you keep driving it for long, it's going to self-destruct and then you'll have to get a replacement (which will also likely need rebuilding...we're talking about 36-year-old parts.) See this post. |
