It is currently Fri Nov 27, 2026 6:16 pm
 Post subject: oil pan?
PostPosted: Mon Feb 26, 2007 5:27 pm
I'm building up a slant from a 69 dart to drop into my 64 valiant. will I run into clearance problems with the 69 pan? thanks
J
64' Valiant Signet 5.9, 64' Dart 170 moredoor 3.7, 67' A100 3.7, 00' Dakota SLT 4.7
PostPosted: Mon Feb 26, 2007 9:13 pm
The 1960 - 66 pan is different from the 67 on up pans, the area between the sump and the front of the pan is longer.
Oil pick-up tubes are also different so swap on the oil pan and pick-up tube from the 64 and you will be OK.
PostPosted: Tue Feb 27, 2007 12:01 pm
awesome photo!! thanks Doug
PostPosted: Fri Mar 02, 2007 4:50 am
Its a good idea to make or install a windage tray in the sump, stops the oil pressure taking a dive on lefthand corners.
Users browsing this forum: Ahrefs [Bot] and 8 guests
