| fuel pump https://slantsix.org/forum/viewtopic.php?t=22071 |
| Author: | WILL'S74 [ Thu Mar 01, 2007 6:59 pm ] |
| Post subject: | fuel pump |
Is the the fuel pump on the slant the same as all small blocks ? And if not can I get a hp pump for my 225? |
| Author: | Doctor Dodge [ Thu Mar 01, 2007 8:34 pm ] |
| Post subject: | Re: fuel pump |
Quote: Is the the fuel pump on the slant the same as all small blocks ? And if not can I get a hp pump for my 225?
The Mopar Big Block fuel pump is a closer match but you still have to swap-in the "arm" from a SL6 fuel pump.DD |
| Author: | cjh [ Fri Mar 02, 2007 4:07 am ] |
Use an electric one, its easier, just have it hooked up to an oil pressure switch to switch it on. I think CAT have them in that thread size, have used them before on 351C Ford and other brands of vehicles.
| Author: | Pat Dawson [ Fri Mar 02, 2007 7:19 am ] |
Aftermarket electric pumps can be noisy for an everyday driver. |
| Author: | SlantSixDan [ Fri Mar 02, 2007 7:47 am ] |
Agreed, I will not put an electric pump on a car not originally so equipped without a good reason (such as a fuel injection retrofit). I do not find them "easier" or more convenient on street-driven carbureted cars. They are also usually noisy, and can be quite unsafe. |
| Author: | Dart270 [ Fri Mar 02, 2007 11:32 am ] |
Unless you are running more than about 250HP (14s 1/4 miles in a 3000lb car), then the stock pump should be just fine. I have two cars in that range to prove it... Lou |
| Author: | cjh [ Fri Mar 02, 2007 6:10 pm ] |
With having an electric fuel pump, its easier to hook up with an immobiliser to stop theft. If you mount an elect' fuel pump properly, it hardly makes a noise. I have one on my SV1 and you can't hear it. The pump is a Pierberg roller cell type, not a Facet type. If you have a crash, and the engine stalls, there's no oil pressure, so the pump don't go, that is what I meant with having it hooked up to a pressure switch, to make it work. |
