It is currently Sat Nov 21, 2026 7:49 am
 Post subject: Leak From Dipstick?
PostPosted: Thu Mar 08, 2007 11:33 pm
Hey Guys&Gals,
Seems everytime i take a hard turn my tranny leaks from sumwhere on top..is it possible that i could be leaking from the dipstick"thingy" <-- dont know the word..heh or is there sumwhere else on top that it could possibly leak from?
PostPosted: Fri Mar 09, 2007 12:10 am
have you checked fluid level in "N", hot after going though all gears?
FSM
Most common problems with fluid pushing out the fill tube:
Overfill of trans- remove/drain extra fluid
Plugged filter- time for a new filter
Plugged breather- behind converter above pump
Areated fluid- air leak in or around pump.....
Were are the signs showing up, firewall?
air movement in the engine bay can cause fluids
to show up were they would not normaly be.
Hard cornering to the left might push fluid out,
but it would have to be really hard and for long time frames,
slopping fluid to one side, pulling air into the filter and causeing areated fluid.......
http://imageevent.com/jeffc
62 D100 225 3sp lwb
64 D100 A318 727pb custom lwb
66 D100 A318 4sp lwb
68 D100 B383 727 swb
65 Belveder A318 727 4d
65 Dart GT LA273 2bbl 904
73 Scamp 225 2bbl 4spOD
Old iron or no iron
