It is currently Thu Jun 11, 2026 11:38 am
 Post subject: just shut off?
PostPosted: Thu Mar 08, 2007 3:15 pm
Befor I get to much time in checking this out hope simple answer is out there.have power starter, amp meter,fuseable link both sides of dash all the usual places check this out when I turn the ignition on power is no longer visible anywhere in the car?thanks for any help. Don
'72 Image Duster /6 with turbo build up
'03 Ram 2500 4x4 w/HEMI 5sp 4:10 posi
My Twister Page
 Post subject: power
PostPosted: Thu Mar 08, 2007 3:40 pm
A common problem; usually a poor connection right at the battery clamp opens up when you try to draw a load. Check for a cracked or corroded clamp.
Users browsing this forum: Ahrefs [Bot], Amazon [Bot] and 5 guests
