Valve size
https://slantsix.org/forum/viewtopic.php?t=22127
Author:  WILL'S74 [ Tue Mar 06, 2007 7:47 am ]
Post subject:  Valve size
First let me tell you what I have done to the head so far. Street strip port and polish. Gasket mach intake and exghaust. Shaved head .050. The stock valves weren't in great shape can anybody recamend a good valve size if I was to upgrade. I have the K64-240-4 comp cam kit that came with timing chain valve springs and lifters. Any info would be great.
Author:  72turboduster [ Wed Mar 07, 2007 9:07 pm ]
Post subject:  valve size
well if u want good performance u will need to get the bowls opened up... the valves im using are out of a early small block ford they are a litle different in the lenght but if ur still running hydralic lifters they will adjust themselves
Author:  Doc [ Thu Mar 08, 2007 9:32 am ]
Are the valve guides in good condition or do they need replacing?
A common size for 3/8 guides is 1.700 intake and 1.440 exhaust.
Author:  WILL'S74 [ Fri Mar 09, 2007 1:42 am ]
Post subject:  Valve guides
Guides are good
