Valve Cover Painting
https://slantsix.org/forum/viewtopic.php?t=22139
Author:  J. Goodman [ Tue Mar 06, 2007 6:41 pm ]
Post subject:  Valve Cover Painting
Have any of you ever painted a valve cover using the bedliner material? I've seen a pickup or two with the spray in bedliner, and think it would look pretty good on a valve cover. If you've done it, got a picture?
Author:  SlantSixDan [ Tue Mar 06, 2007 7:08 pm ]
Eek. The mental image I come up with is those messy engine bays where someone has taken in a car to be undercoated, and the shop does a sloppy job and gets that gunk all over everything.
Black or red crackle-finish paint I can understand using on a valve cover, if you're willing to wash the engine periodically to keep it clean. Factory-type engine paint, I can understand using, too.
But bedliner material...? :shock:
Author:  Ron Parker [ Tue Mar 06, 2007 7:40 pm ]
Powder coating is the best way to go. Drake Coatings can do this for you and it will be the best. Thanks Ron Parker :D
Bagels On Juice Im On Boost
Author:  emsvitil [ Tue Mar 06, 2007 8:17 pm ]
Isn't it some sort of plastic?
I'd think it would melt.............
:cry:
Author:  SlantSixDan [ Tue Mar 06, 2007 8:36 pm ]
Yes, powder coating is plastic.
No, it won't melt.
Author:  emsvitil [ Tue Mar 06, 2007 8:53 pm ]
No, it won't melt.
not the powder coat, the bed liner.............
Author:  AnotherSix [ Tue Mar 06, 2007 8:58 pm ]
But you could throw your tools on it without scratching. I don't think it's made for the heat either. Not my personal taste for underhood detailing either.
Author:  BigBlockBanjo [ Tue Mar 06, 2007 9:39 pm ]
No, it won't melt.
Although your slant won't get hot enough(hopefully!)to melt it, powder coat actually does melt.......that's how you get the finish. :D
