| just shut off? https://slantsix.org/forum/viewtopic.php?t=22161 |
| Author: | Mister Twister [ Thu Mar 08, 2007 3:15 pm ] |
| Post subject: | just shut off? |
Befor I get to much time in checking this out hope simple answer is out there.have power starter, amp meter,fuseable link both sides of dash all the usual places check this out when I turn the ignition on power is no longer visible anywhere in the car?thanks for any help. Don |
| Author: | KBB_of_TMC [ Thu Mar 08, 2007 3:40 pm ] |
| Post subject: | power |
A common problem; usually a poor connection right at the battery clamp opens up when you try to draw a load. Check for a cracked or corroded clamp. |
