| Aftermarket gauge wiring advice? https://slantsix.org/forum/viewtopic.php?t=22169 |
| Author: | RDJ [ Fri Mar 09, 2007 9:59 am ] |
| Post subject: | Aftermarket gauge wiring advice? |
| Author: | KBB_of_TMC [ Fri Mar 09, 2007 11:04 am ] |
| Post subject: | aftermarket |
RadioShack isn't what it used to be... Anyway, if you can find a little barrier strip, that would provide an easy and reliable junction point. It's just a block of plastic with eyelets and screws and doesnt' cost much. The current you need for the gauges is small, but I would stick with #14-16 wire just so it's less likely to get broken. Grounding at the column ought to be fine IF the little jumper from the column to the dash is in place! |
| Author: | 75 slanted swinger [ Sat Mar 10, 2007 5:48 am ] |
In my 75 Dart I ran a 14g wire from a barrier strip I have mounted near the battery to one of the 1/4 studs that holds the steering colum up. Then I put a small jumper wire to other stud. Any wires that need grounding in this area go to one stud or the other. thanks jeff |
| Author: | 64'4$peed [ Sat Mar 10, 2007 10:02 am ] |
you can run all your lighting wires together no problem. just like your grounds. I recommend that you install the lights to your dash dimmer on the headlight switch. then your aftermarket and stock gauges all dim together. an inline fuse is also a good idea. |
| Author: | RDJ [ Sat Mar 10, 2007 12:23 pm ] |
Quote: you can run all your lighting wires together no problem. just like your grounds. I recommend that you install the lights to your dash dimmer on the headlight switch. then your aftermarket and stock gauges all dim together. an inline fuse is also a good idea.
Thanks for the replies. I will not have any stock gauges left when I am done. What amp fuse would you recommend?
