It is currently Fri Oct 09, 2026 3:27 am
 Post subject: Slot length/Dizzy
PostPosted: Mon Mar 12, 2007 8:13 pm
O.K.. I read for 1 hour after searching for "recurving". Part # is:3656257. It has points, with an adjustable vac. advance. It has 9.5X stamped on the arm. It also has the "high-performance" 15R piece. :shock: :D
My question is, how long is the slot on a 10R? I read and read, but I either ran over it, or didn't understand.
This is the only dizzy I have, so I'd rather do it right the first time.
Thanks guys,
BBBanjo
225 Cubic Inches of Iron-Head American Muscle
225 bored .040 /.100 off block, Schneider Cam 224@.050~ .480 lift - Stock valves, blended bowls, Offenhauser intake with 500 Edelbrock carb
PostPosted: Mon Mar 12, 2007 8:52 pm
To determine slot length you need to do some measuring and some math...........
1. Measure diameter of pin
2. Measure length of existing slot
3. 2. - 1. = existing movement available
4. 3. / (existing degrees advance) = distance per degree
5. 4. * (degrees wanted) = movement wanted
6. 5. + 1. = new length of slot.
PostPosted: Mon Mar 12, 2007 8:53 pm
Where do you set your initial advance and how much total do you need??
PostPosted: Tue Mar 13, 2007 9:43 am
emsvitil, thanks for the info!
Doc: I have no idea. I'm getting ready to start up my slant for the first time. I did understand I want alot of initial, I just thought I'd go ahead and modify the part before, so I have that much less to deal with later.
I'll be driving everyday, so I don't need a race curve...just something to go with the better cam and intake. I'll have to fine tune it after she gets broke in.
Thanks,
BBBanjo
 Post subject: Uff...
PostPosted: Tue Mar 13, 2007 12:32 pm
If you're just starting up the motor for the first time, just run the stock distributor at a lower setting like TDC so you can break it in without worry of pinging, then once everything is 'worn in /worked out' then you should change your timing curve... Even my timing curve is nothing like it was when I started my mill the first time...better safe than sorry...
Time to get a second distributor (one for driving, and one for 'testing').
Users browsing this forum: No registered users and 26 guests
